window平台上copy /b 两个文件 本质上是如何实现的?
原文转载自:https://www.zhihu.com/question/27971703   作者:pezy
根据 Appending Binary Files Using the COPY Command 可粗略的认为,就是以二进制的方式合并两个文件到一个新文件中。
举例说明:
echo Hello > 1.txt
echo World > 2.txt
copy /b 1.txt+2.txt 3.txt
那么此刻 3.txt 中应该是
Hello
World
如果仅仅实现上述例子中的基本功能,使用几个系统的 API 就可以搞定。代码如下:
#include <windows.h>
#include <stdio.h>
void main()
	HANDLE hFile;
	HANDLE hAppend;
	DWORD  dwBytesRead, dwBytesWritten, dwPos;
	BYTE   buff[4096];
	// Copy the existing file.
	BOOL bCopy = CopyFile(TEXT("1.txt"), TEXT("3.txt"), TRUE);
	if (!bCopy)
		printf("Could not copy 1.txt to 3.txt.");
		return;
	// Open the existing file.
	hFile = CreateFile(TEXT("2.txt"), // open 2.txt
		GENERIC_READ,             // open for reading
		0,                        // do not share
		NULL,                     // no security
		OPEN_EXISTING,            // existing file only
		FILE_ATTRIBUTE_NORMAL,    // normal file
		NULL);                    // no attr. template
	if (hFile == INVALID_HANDLE_VALUE)
		printf("Could not open 2.txt.");
		return;
	// Open the existing file, or if the file does not exist,
	// create a new file.
	hAppend = CreateFile(TEXT("3.txt"), // open 3.txt
		FILE_APPEND_DATA,         // open for writing
		FILE_SHARE_READ,          // allow multiple readers
		OPEN_ALWAYS,              // open or create
	if (hAppend == INVALID_HANDLE_VALUE)
		printf("Could not open 3.txt.");
		return;
	// Append the first file to the end of the second file.
	// Lock the second file to prevent another process from
	// accessing it while writing to it. Unlock the
	// file when writing is complete.
	while (ReadFile(hFile, buff, sizeof(buff), &dwBytesRead, NULL)
		&& dwBytesRead > 0)
		dwPos = SetFilePointer(hAppend, 0, NULL, FILE_END);
		LockFile(hAppend, dwPos, 0, dwBytesRead, 0);
		WriteFile(hAppend, buff, dwBytesRead, &dwBytesWritten, NULL);
		UnlockFile(hAppend, dwPos, 0, dwBytesRead, 0);
	// Close both files.
	CloseHandle(hFile);
	CloseHandle(hAppend);
将代码中的 1.txt, 2.txt, 3.txt 改为任何别的文件,是一样的。如题主补充的要求,做如下替换即可:
2.txt -> b.txt
3.txt -> c.txt (文本),c.jpg(更改后缀,成为图片)
诸如 jpg 之类的格式,依然是二进制文件,经过渲染,表现为图片而已。
 5  已被阅读了324次  楼主 2017-08-23 14:08:22
回复:window平台上copy /b 两个文件 本质上是如何实现的?
您的IP:54.160.153.233,2018-02-26 09:27:30,Processed in 1.0625 second(s).
